Gbh4
Mar 31, 2019Aspirant
XR700 r-apps not loading
I’ve just got the XR700 and none of the R-apps are loading.
The router is on the latest firmware as it updated itself during intial setup.
I’ve done a full factory reset and still no differen...
Mar 31, 2019Guru - Experienced User
Does this happen with Firefox or Opera on v10 FW?
Be sure to clear all broswer caches, exit the browser the relaunch.
- Gbh4Mar 31, 2019Aspirant
It's not browser specific. In my post I did mention it's the same on my iPad too.
In any case, I've sorted it. It needed several factory resets before finally coming to life.
Not what I would expect at £450!- FURRYe38Mar 31, 2019Guru - Experienced User
Ok, sounds like you got it worked out.
Next time, might try a full re-load of the FW, factory reset and setup from scratch.
Enjoy.
- Netduma_JackApr 02, 2019NetDuma Partner
Could you try downgrading back to the previous firmware (.8). This may fix your problem: https://kb.netgear.com/000060499/XR700-Firmware-Version-1-0-1-8
