Gbh4
Mar 31, 2019Aspirant
XR700 r-apps not loading
I’ve just got the XR700 and none of the R-apps are loading.
The router is on the latest firmware as it updated itself during intial setup.
I’ve done a full factory reset and still no differen...
Mar 31, 2019Guru - Experienced User
Does this happen with Firefox or Opera on v10 FW?
Be sure to clear all broswer caches, exit the browser the relaunch.
Gbh4
It's not browser specific. In my post I did mention it's the same on my iPad too.
In any case, I've sorted it. It needed several factory resets before finally coming to life.
Not what I would expect at £450!
- FURRYe38Mar 31, 2019Guru - Experienced User
Ok, sounds like you got it worked out.
Next time, might try a full re-load of the FW, factory reset and setup from scratch.
Enjoy.
- Netduma_JackApr 02, 2019NetDuma Partner
Could you try downgrading back to the previous firmware (.8). This may fix your problem: https://kb.netgear.com/000060499/XR700-Firmware-Version-1-0-1-8
