Gbh4
Mar 31, 2019Aspirant
XR700 r-apps not loading
I’ve just got the XR700 and none of the R-apps are loading.
The router is on the latest firmware as it updated itself during intial setup.
I’ve done a full factory reset and still no differen...
Gbh4
It's not browser specific. In my post I did mention it's the same on my iPad too.
In any case, I've sorted it. It needed several factory resets before finally coming to life.
Not what I would expect at £450!
Mar 31, 2019Guru - Experienced User
Ok, sounds like you got it worked out.
Next time, might try a full re-load of the FW, factory reset and setup from scratch.
Enjoy.
