Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
Valaka
Dec 03, 2019Tutor
I came here with the same issue after my router updated itself to XR700-V1.0.1.20. I put up with it for a few months then decided to fix it and figured I would just manually install the firmware update. So I downloaded the same firmware that the router automatically updated and installed and it fixed the issue. So possibly the auto install of the firmware is the issue. At least it was for me.
https://www.netgear.com/support/product/XR700.aspx#Firmware Version 1.0.1.20
Hope this helps someone.
