Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
Brado78
Jan 07, 2020Star
Re: XR700 geofilter not working
So have been successfully using .12 for a while now on the XR700 with no issues smoothest my connection has ever been and works great with the SX10 switch. So after having issues upgrading to the firmware .20 thanks to Robs help with a work around regarding a issue to do with the Nintendo switch. Also discovering causes same issue with Nintendo Wii both causing r-apps not loading.
However used it for a couple of days everything seemed fine however also notice the geo filter was not working correctly and would let other players from USA joint my lobby. But was no indication this was happening due to no symbols appearing.
So have downgraded back to firmware version.12 on XR700.
Just thought I better let you all know just in case others have same issue with geo filter not working.🙂👍
AveGuysGaming
Jan 12, 2020Tutor
I was having the same issues and thanks to your help with this post it seems to be fixed. I rolled back to version 1.2 i have all mt R-apps again and i was able to edit all my Nintento ststems to Xbox. only time will tell if i still have network dropouts radomly for no reason.
Netgear come on I love your products and for something this stupid to cause issue isnt ok. Hope you guys get this fixed correctly and quickly. I'm a Youtube content creator and i depend on my systems.
