Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
Hartsgrove
Feb 19, 2020Apprentice
So your advice to everybody is do the stupid hot fix which clearly still did not fix my issue my router has been unplugged in the box for over two months I was promised by duma os and I was promised by Netgear that you were working very closely together to come out with a new update to fix this issue. I have been told countless times please be patient we’re working on it we’re fixing it we’re coming out with an update and you were doing nothing but lying to the public. I did every single step you people told me to do I did every single step with Netgear level two support they have documented over eight hours of data they got from the router with remote access over a seven days span. So the new advice is put this hot fix on there hopefully it works if it doesn’t then they made out with $500 who cares.
Netduma-Fraser
Feb 19, 2020NetDuma Partner
Did you perform a factory reset after applying the hotfix as that is recommended. We're not throwing it out and just leaving it at that, if it still isn't resolved then we'll keep working on it. There is also another firmware for a security fix that would encompass this fix as well so I would advise upgrading to that anyway https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
