Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
SubRetro
Mar 13, 2020Tutor
Just wanted to provide an update. So far the R-Apps and other menus appear to be working as intended without getting the errors that was mentioned previously. I will keep working with it and circle back on Monday.
One thing I did start playing with and noticed wasn't working was the Site content blocking. Basically if I put in a keyword such as "playboy" or www.playboy.com, it blocks wireless devices but wired devices don't get blocked. I can certainly move this into another support case and forum post if needed I just wanted to mention it in the event it was FW related. I am just looking for good parental security. Thanks again for your help.
Netduma-Fraser
Mar 13, 2020NetDuma Partner
That is great to hear! I am surprised at all to be honest that worked as that feature only works for HTTP and most sites now use HTTPS. I would look into using DynamicDNS which you can use with the router to provide some parental security.
- SubRetroMar 14, 2020Tutor
Any good DynDNS provides that would work? Would it be worth it to look at Circle? Maybe Cisco Umbrella?
- Netduma-FraserMar 14, 2020NetDuma PartnerI haven't used DDNS myself in a parental capacity so I couldn't say exactly, comes down to whether you want something free/paid and what they can each offer compared to your needs.
