Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
Hartsgrove
Mar 24, 2020Apprentice
I’ve been trying to send you pictures of my ping doing speed test through your router and then in game it won’t allow me to attach phots. I refuse to create a new thread because this is getting so much attention maybe they will actually legally have to do something. My pain right now is between 80-125 Games are completely unplayable. Also anytime I make a change to Geo filter it gets frozen and then I get a 402 bad gateway error. I reinstalled the .22 firmware factory reset and re-did the router and it’s doing the exact same thing. Geo filter literally does not work at all again if it’s the size of the world or as small as my state I’m still getting put in games with super high ping no matter what. And by high ping I mean 80-125 if not higher. My isp was here three times this week and tested every outside line up and down the block and replaced every wire to my home and inside my home and there equipment to test single is great all numbers are excellent. I actually showed me and I took a picture of the machine with a green checks next to everything with every number coming from their node. I still can’t play with friends after adding them through Geo filter they have a static IP as well. The high ping is completely out of hand. I’ve never seen a router keep placing someone in a game with ping over 80. The only thing circled in Geo filter is New Jersey literally it takes five minutes to find a game and put me in a game 80-125 ping Completely laggy unplayable
Netduma-Fraser
Mar 24, 2020NetDuma Partner
Netgear don't look at the community forums, they only responds to tickets people have made or who have called - that is how they provide their support. I, however respond to every topic that appears in this sub forum and so it would help me help you if a new topic could be made. If you can't upload directly here then use something like imgur.com and link to it and then I can have a look and compare it to your issues.
