Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
RPam
Apr 24, 2020Aspirant
Hi All,
I have an XR700 and the network monitor, device manager and qos do not appear.
Instead the error message appears "This R-App isn't loaded yet, please try again in a minute". I have looked through this thread and tried most of the solutions already.
- Things like setting the retry rate under system information to 5 instead of 3.
- I reverted the firmware back to the previous version v1.0.1.10.
- Did a factory reset on the router and recreated my network.
It works for about 30 mins after powercycling the router and the modem. But eventually the error returns.
I saw something about a version patch in this thread that have helped people, although I can't access it because it is not on the official support page.
Is there a fix for this yet? And if so would someone be able to PM it to me?
-R
- Devil_Dog_1888Apr 25, 2020TutorThis is the hotfix that should help with the R-APPS issue. However I will caution you, I have found another annoying bug with this release. I am in the process of drafting a new thread, but just have not had a chance to post it yet. In short, because I do not want to get into the gritty details here, I found myself having to reboot this router at least once every 5 to 7 days because it stops handling DHCP. Many of the devices on my network start to get 169 addresses. A reboot of the router fixes it. Once I have started the new thread I will link it here so the others can follow.
Here is the link to the hotfix. It is actually listed on netgear's page for this router, but it is buried.
https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix- Netduma-FraserApr 25, 2020NetDuma PartnerAs above that firmware link should resolve the issues you're having.
- KeBousquetMay 07, 2020Aspirant
I too have had the R Apps issue. Tried the hotfix you suggested. Did a factory reset and nothing has helped.
Please advise.
