Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
TotalEnigma
May 08, 2020Guide
I just purchased this router and was experiencing the R-Apps issue described earlier in the thread. I was constantly having to reboot the router to use certain R-Apps, and even then some of them wouldn't work. Turns out it was all my Nintendo devices (1x - 3DS, 3x - Switches) that were causing the problem. I could use all the R-Apps until any of my Nintendo devices connected to the network then they would stop working. To get around this I had to do the following...
- Attach all 4 devices to the network so they show up in the list of attached network devices. (This causes certain R-Apps to break but that's OK at this point)
- Completely power off all of the Nintendo devices so they are no longer on the network. Putting the Switches to sleep is not enough, you need to actually turn them off. It is important at this point that none of the Nintendo devices try to access the network in any way.
- Reboot the router to bring the broken R-Apps back online.
- Go into the Device Manager App (it should work now) and update the records for every Nintendo device. Giving them all unique names and selecting the appropriate device type for each.
- Turn on each Nintendo device and check that it is back on the network. You should still be able to use the "Device Manager" applet now.
It appears that even though the Nintendo devices display a device type in the "Device Manager" list, the records for those devices don't actually contain the device type which may be causing the applet to crash.
Not sure if my solution will work for everyone, but it appears to have fixed mine.
jonathan0216
May 09, 2020Aspirant
your the man that seems to be the issue it works now thank you better than waiting for these guys to answer a phone or send you to the right person, your the man.
TotalEnigma wrote:I just purchased this router and was experiencing the R-Apps issue described earlier in the thread. I was constantly having to reboot the router to use certain R-Apps, and even then some of them wouldn't work. Turns out it was all my Nintendo devices (1x - 3DS, 3x - Switches) that were causing the problem. I could use all the R-Apps until any of my Nintendo devices connected to the network then they would stop working. To get around this I had to do the following...
- TotalEnigmaMay 11, 2020Guide
Thanks, glad I could help. Wasn't sure if I just got lucky or if my solution would work for others as well.
- jonathan0216May 11, 2020AspirantYea seems to be the issue is the Nintendo i had the XR500 and I didn’t have that problem so I followed what you said to do and it worked great, but that’s a huge issue for people who buy this product just to use it as a router. Netgear should not be sending out products that don’t work it’s been months of these threads and they still haven’t done anything for the people who actually bought this item or even acknowledged to fix the issue which is crazy on so many levels because this Xr700 is 500 dollars this should never happen with any company with products this expensive.
- AnonymousMay 11, 2020
I have a Nintendo Switch but it is not even on - it is actually dead and has been for weeks. ANY ROUTER THAT DOES NOT FIRST DO NO HARM IS A LIABILITY and not an asset. Changing a device type in device manager should not make the router treat that device differently in any way - it should only exist for labeling purposes.
It has been 6 days since I reset the XR700 and added my DHCP reservations for every device. That has helped it to last more than a day - but not much past 6 days it appears. I now am getting the R-Apps not loading issue again. I bought this thing in December and ever since, it has been a headache. I called Amazon and they are waiting on hold for me to talk to Netgear. We were #28 in one queue and then we had to join a different (Nighthawk) queue after the Amazon rep spoke to someone.
An update/fix for this should be immediate.
