Nigel_Holland
Nov 17, 2019Guide
XR700 r-apps not loading
Hi Guys, Looking for some help on r-apps not loading on the XR700. I see there is a closed thread on this already but does not give me much information. Is anyone able to help on this one? ...
- Nov 17, 2019Hi Nige, what pages is this happening on? In System Information on the R-App panel, change in the options the retries to 5 instead of 3 and then reboot the router.
Netduma-Fraser
Jun 18, 2020NetDuma Partner
Sorry to hear you're having the issue again .24 should have resolved that. I would recommend you sign up for the 3.0 beta so you can see if it's fixed there and if not it provides the perfect opportunity to provide feedback. The beta will kick off soon - XR500 has already begun for a first group of testers. http://www.netgearinnovation.com/dumaos-beta/index.html
Aardappel
Jun 18, 2020Tutor
Thank you for your response Netduma-Fraser
I have subscribed for the 3.0 betá and i hope the first testers can test in the very near future.
I will leave my router as it is at the moment. I have no time/patience to re-do all configs i've made again.
- Retired_MemberJul 11, 2020
I think everyone with this issue should describe Netgear's and NetDuma's lack of support here:
