PCLLC-JFenn's avatar
Aug 11, 2020
XR700 R-Apps Not Responding / Crashing and Missing Device Classification
R-Apps will crash - even on fresh restart of unit.  Also when in Device Manager (when it actually works) I don't have the option to set my Nighthawk EX7500 extender as a WiFi extender.  Maybe you should add this in the 3.0 firmware as I'm sure people do use WiFi extenders and this model does support "Smart Roaming" with WiFi extenders. Also, when are we expecting the new FW release or beta?  This old FW is getting very combersome and doesn't want to stay working.
-Jeremy Fenn
    • PCLLC-JFenn's avatar
      PCLLC-JFenn
      Tutor
      Fraser, I am already on this FW version.  It does not fix the issue. Also, concerning the extender, I do have it set up (via the ex7500 itself), I'm just simply talking about where it shows in the Device Manager section of the admin GUI where I could label it as a Computer or XBox, etc.  There is no option to label it as an extender.  I would assume the labels we use for these devices in Device Manager coorelate with how their traffic is prioritized in the QoS?  As I said previously, since this router does support mesh, I would think in Devices Manager we could set an extender as an "Extender" and not have to label it as a "Computer" or "Printer" or "Xbox" etc.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you clarify what you mean by Crash - Rapp not loaded? Do you actually see it as a device in the Device Manager? As in theory you shouldn't see it as it's just extending the WiFi, does it get assigned an IP? Only the console device types can dictate that, the other devices are not used in the same way and are more for aesthetic purposes.
