CSPHX101
Oct 16, 2019Aspirant
XR700 Reset Dashboard panel
Beta firmware XR700 V1.0.1.20
- I made some adjustments to my dashboard panel .. need a way to reset without restoring to factory defaults.
- Wireless setup screen/ areas should be disabled when radio is disabled.
Keep up the good work!
Thx
1 Reply
- Netduma-FraserNetDuma PartnerNo way to reset it directly but here is the default layout: https://forum.netduma.com/uploads/monthly_2019_10/1038413266_Screenshot(116).thumb.png.7e619a46205fecf0e8f3bf0e618c5b9d.png its for the XR500 but is the same for the XR700.
