Leo1garcia1
Oct 15, 2023Follower
XR700 Router stopped broadcasting SSID
Anybody got a fix for 2.4 band not working but 5 band is working perfectly.
Netduma-Fraser
Oct 15, 2023NetDuma Partner
Are you using Smart Connect and do you notice whether it works with it enabled/disabled?
iamsotorious
Oct 29, 2023Aspirant
Hello. I am having this exact same issue. I went to login to check something in my settings. As it was trying to login it kicked me off the internet. Once I got reconnected again. It did the same.
I just spent the entire night trying to figure it out
I get the message of dumasos can’t load. I also don’t have the lights emitting on my router for WiFi on 2.4 and 5ghz. I also can not connect to WiFi
I have tried everything suggested. Even went back to an older version which almost bricked my router. Back on current to atleast get Ethernet. I couldn’t with an older
Please people who follow these threads. It’s something deeper than the basics I went back to many year old threads and most of them left unresolved. I’ve had many issues with this XR700 and it might be time for it to get replaced.
- Netduma-FraserOct 29, 2023NetDuma PartnerI think it is a hardware issue, apparently the normal Nighthawk equivalent suffers the same issue
- iamsotoriousOct 29, 2023AspirantYou think it got fried when I logged into dumas? It was so weird the second I logged internet bricked.
- Netduma-FraserOct 29, 2023NetDuma PartnerI don't think it would have specifically been that, the WiFi drivers probably failed. I've not seen anyone able to recover it unfortunately.
