Leo1garcia1
Oct 15, 2023Follower
XR700 Router stopped broadcasting SSID
Anybody got a fix for 2.4 band not working but 5 band is working perfectly.
iamsotorious
Oct 29, 2023Aspirant
Hello. I am having this exact same issue. I went to login to check something in my settings. As it was trying to login it kicked me off the internet. Once I got reconnected again. It did the same.
I just spent the entire night trying to figure it out
I get the message of dumasos can’t load. I also don’t have the lights emitting on my router for WiFi on 2.4 and 5ghz. I also can not connect to WiFi
I have tried everything suggested. Even went back to an older version which almost bricked my router. Back on current to atleast get Ethernet. I couldn’t with an older
Please people who follow these threads. It’s something deeper than the basics I went back to many year old threads and most of them left unresolved. I’ve had many issues with this XR700 and it might be time for it to get replaced.
Netduma-Fraser
Oct 29, 2023NetDuma Partner
I think it is a hardware issue, apparently the normal Nighthawk equivalent suffers the same issue
- iamsotoriousOct 29, 2023AspirantYou think it got fried when I logged into dumas? It was so weird the second I logged internet bricked.
- Netduma-FraserOct 29, 2023NetDuma PartnerI don't think it would have specifically been that, the WiFi drivers probably failed. I've not seen anyone able to recover it unfortunately.
- FURRYe38Dec 02, 2023Guru - Experienced User
Something to try and see if this might help:
https://forum.netduma.com/topic/51612-new-xr700-beta-firmware-33363/?do=findComment&comment=385598
- iamsotoriousDec 03, 2023Aspirant
i got rid of the router, to unpredictable for me. thanks though hopefully this helps someone in the future.
