Mikeclev7
Dec 25, 2019Aspirant
XR700 Router stopped broadcasting SSID/no wifi
Yesterday afternoon, my wifi stopped working. What I mean is I could no longer find the SSID, on any device, and cannot connect. When I log into the admin page, on the home page it shows the wireless ...
SonzofGod
May 17, 2020Tutor
Did you ever solve this issue? My year old XR700 suddenly started doing this yesterday.... SSID is not showing or intermittent. The WiFi radio button the front appears to do nothing....as well as the Duma OS enable radio button checkbox. Also, the router WILL NOT let me do a factory reset. The power LED just flashed white while I have the reset button pressed....never goes orange.
ALL GHz bands show disabled in the DUMA OS....
Mikeclev7
May 17, 2020Aspirant
No I never did, I had no choice but to contact amazon and get a refund. For a faulty product. I tried netgear support, they were of no use to me. Not to mention hardly being able to understand them. Definitely not buying another netgear product, that’s my solution. No reason you spend $500 on a router and it quits only a couple months in.
- SonzofGodMay 17, 2020Tutor
thank you for the fast reply....I will try and troubleshoot it a bit...but it seems alot of people are having this issue....the router is so advanced it can't do simple things like provide internet lol
