Aadlon
May 24, 2021Aspirant
XR700 Router stopped broadcasting SSID/no wifi
I See Netgear Closed This Original Thread With No Solution.. Support Was No Help. Told Me To Take It To Best buy Or Something To See If They Could Fix It. Was Told It Is A Common Problem And They ...
May 25, 2021Guru - Experienced User
I don't see any other posts from you on this device.
You have the XR700?
What firmware is on it?
what modem/gateway is it connected to?
What actual issue (in details since we aren't there) are you having?
Aadlon
May 27, 2021Aspirant
Yes. Xr700. I think cm1000 for modem.
Not Sure I Don't Have It Hooked Up In Front Of Me, But had The Latest Firmware.. Tried HotFix Firmware. loaded Virgin (Default) Firmware Via Tftp. It Will Go Through The Setup Wizard But As Soon As It Attempts To Load dumaos IT Displays "dumaos not loaded yet! don't worry we will redirect you shortly.". I Can Get Into The Advanced Console It Shows The 2.4g And 5g Wifi Bands Grayed Out. Can't Enable Then. The Wifi Lights On top Are Also Off For The 2.4 And 5g Bands. 160g Light Is Lit. Wifi Off Switch Is Not Enabled. Tried Multiple Resets. Multiple Firmware With No Luck. Already Have Hours Into Troublshooting. CS Told Me To Take It To Bestbuy To see If They Can Repair It. Thing Is 2yrs Old But Probably has Less Than A Yr Of Use. Not Impressed For A +$500 Router.
