dlsissoni
Feb 23, 2019Follower
XR700 router will not connect to internet!!!!!
Trying to configure a brand new XR700 router from an iMac. Followed intructions to the TEE! When I go to routerlogin.net, it tells me that I have no internet connection and the internet light NEVER c...
Netduma-Fraser
Feb 23, 2019NetDuma Partner
Can you access the interface using the LAN IP of the router? If you can access it, manually go through the setup wizard, does it work then?
