lextheimpaler
Apr 03, 2019Aspirant
XR700 seperate 2.5ghz and 5Ghz or stick to smart connect?
Should i stick to smart connect or seperate? What settings to be used ie. Channel? Im only getting 900Mbps for 5GHZ
Apr 03, 2019Guru - Experienced User
What devices are you using with the XR700?
Is 160Mhz enabled on the XR?
- lextheimpalerApr 04, 2019Aspirant
to enable 160Mhz do i need to turn off smart connect?
- FURRYe38Apr 04, 2019Guru - Experienced User
See if it will enable with SC enabled.
