lextheimpaler
Apr 03, 2019Aspirant
XR700 seperate 2.5ghz and 5Ghz or stick to smart connect?
Should i stick to smart connect or seperate? What settings to be used ie. Channel? Im only getting 900Mbps for 5GHZ
schumaku
Apr 03, 2019Guru - Experienced User
Nothing wrong with having a single user friendly network name and seamless roaming between the 5 GHz and the 2.4 GHz network, e.g. when moving away from the router where 5 GHz dos become difficult, isn't it?
Ideally channels not used in the neighbourhood - what can be difficult in a dense environment. A WiFi test app like Netgear's can help identifiy the other networks - the visible ones at least.
Not a regular XR user, there might be a control to enable HR160.
Throughput (that would be wow!) or negotiated link rate? What client, what distance, what obstacles, ...?
lextheimpaler
Apr 04, 2019Aspirant
Througput less than 2 feet to the router
- schumakuApr 04, 2019Guru - Experienced User
What kind of wireless client (make, model, ...)?
For a good 802.11ac client, 900 Mb/s is a very good peak up- and downstream spead on 5 GHz - around the max you can expect.
