lextheimpaler
Apr 03, 2019Aspirant
XR700 seperate 2.5ghz and 5Ghz or stick to smart connect?
Should i stick to smart connect or seperate? What settings to be used ie. Channel? Im only getting 900Mbps for 5GHZ
lextheimpaler
Apr 04, 2019Aspirant
Througput less than 2 feet to the router
schumaku
Apr 04, 2019Guru - Experienced User
What kind of wireless client (make, model, ...)?
For a good 802.11ac client, 900 Mb/s is a very good peak up- and downstream spead on 5 GHz - around the max you can expect.
