strykewave
Jan 30, 2019Guide
XR700 SFP+ problems.
Hi, I have an XR700 Nighthawk router and an SX10 progaming switch. My PC has an Aqtion aqc 107 10g lan port. Ive Rma'd the netgear axm765 in hopes that it was the problem got a new one plugged it in ...
- Feb 01, 2019
Hi Strykewave in regards to the 10GB connection my friend and I both have an Xr700 and we had lots trouble getting it to work.
The XR700 should automatically pick up the 10gb connection, the only thing we had to change for it to be noticed and work if by the following steps.
1. In XR700 got into internet settings;
2. Under "SFP+ Module Dection": Change that from auto to "DAC mode only"
3. Now the 10gb light should be on the XR700 providing you have a AXM765 Transceiver pluged into the 10Gb port.
Link: https://www.netgear.com/business/products/switches/modules-accessories/axm765.aspx
Once Done
Got into Monitoring in the XR700, then statistics and you should see data flowing in the SFP+ section
See attached photo for your records hope this helps u mate.
Kind Regards,
Dogga
strykewave wrote:
Selected games console under traffic prioritization and the red light came on. Although its pc i dont care as long as it works. Now on the the 10g issue.
Netduma-Fraser
Jan 30, 2019NetDuma Partner
Okay well hopefully you'll hear back, keep us updated and I'll have a think about what the issue could be.
Thats odd because that option should actually prioritize your game, does the red light appear to indicate it's being prioritized when turned on? Do you also have Anti-Bufferbloat set to 'Always'/'When high priority traffic detected' with the sliders lowered (we recommend 70%)?
strykewave
Jan 30, 2019Guide
Yes that is correct the weird thing is its the only game that has the issue, I play Pub g Ring of elysium, and Dayz all online games with no issues.
