Michael123
Dec 10, 2019Tutor
XR700 sfp+ slow download speed
Hi All, I use the xr700 for 1 week now with no issues, today i received my sfp+ module for the 10Gb. I powerd down the router and installed the sfp+ in the router and connected the cat7 cable...
Netduma_Alex
Dec 10, 2019NetDuma Partner
I'm sorry I didn't quite understand from your message what speed you're getting from the SFP+ port and what speed you're expecting?
- Michael123Dec 10, 2019TutorHi,
I'm getting 410mbps on the sfp+, when I plug the same cable in Port 1 of the router I'm getting 990mbps like normal.
Desktop is 1000mbps card but that should be a problem as it is backwards compatible right?- Netduma-FraserDec 10, 2019NetDuma PartnerHave you switched to sfp in Internet Setup?
- Michael123Dec 10, 2019TutorNo, I'm using this for LAN.
I just wanted to test the fsp+ module before buying the sx10 to connect it on the sfp+.
