Michael123
Dec 10, 2019Tutor
XR700 sfp+ slow download speed
Hi All, I use the xr700 for 1 week now with no issues, today i received my sfp+ module for the 10Gb. I powerd down the router and installed the sfp+ in the router and connected the cat7 cable...
Michael123
Dec 10, 2019Tutor
Hi,
I'm getting 410mbps on the sfp+, when I plug the same cable in Port 1 of the router I'm getting 990mbps like normal.
Desktop is 1000mbps card but that should be a problem as it is backwards compatible right?
Netduma-Fraser
Dec 10, 2019NetDuma Partner
Have you switched to sfp in Internet Setup?
- Michael123Dec 10, 2019TutorNo, I'm using this for LAN.
I just wanted to test the fsp+ module before buying the sx10 to connect it on the sfp+.- Netduma-FraserDec 10, 2019NetDuma PartnerUnderstood, could you disable QoS in the Anti-Bufferbloat option menu please and see if the speeds improve?
- Michael123Dec 10, 2019TutorGoodmorning,
I tried it, but no speed improvements
