Michael123
Dec 10, 2019Tutor
XR700 sfp+ slow download speed
Hi All, I use the xr700 for 1 week now with no issues, today i received my sfp+ module for the 10Gb. I powerd down the router and installed the sfp+ in the router and connected the cat7 cable...
Netduma-Fraser
Dec 10, 2019NetDuma Partner
Have you switched to sfp in Internet Setup?
Michael123
Dec 10, 2019Tutor
No, I'm using this for LAN.
I just wanted to test the fsp+ module before buying the sx10 to connect it on the sfp+.
- Netduma-FraserDec 10, 2019NetDuma PartnerUnderstood, could you disable QoS in the Anti-Bufferbloat option menu please and see if the speeds improve?
- Michael123Dec 10, 2019TutorGoodmorning,
I tried it, but no speed improvements- Netduma-FraserDec 11, 2019NetDuma PartnerI think it would be best if you made a ticket with Netgear as it's potentially a hardware issue: http://support.netgear.com/ if it's something on the DumaOS side then they can let us know as it may be something we'll need to fix.
