numo38
Oct 30, 2018Follower
XR700 sft+
Can I use Cisco SFP-10G-T-S Compatible 10GBASE-T SFP+ Copper RJ-45 30m Transceiver Module on my XR700
schumaku
Oct 30, 2018Guru - Experienced User
Thank you Netduma-Fraser for the Kudo - now what if (the OP sent me a PM) an SFP+ is not recognized, or the user can't figure out how ot use the SFP+ on the XR700? Is there a shell access to check the Kernel output once an SFP+ module is plugged?
Netduma-Fraser
Oct 30, 2018NetDuma Partner
I'm not aware if there is unfortunately. I'd advise contacting Netgears support directly in that case.
