someguy28
Mar 09, 2019Aspirant
xr700 slow internet speeds wired
i just got my router and my internet speeds are cut more then half download is ussually 400 plus but it only reaches 110 i have disabled qos and its fine but if its enabled thats when it happens im n...
someguy28
ok so i think i have figured this whole speed problem if your like me and boosted your internet speeds after you got your router then u need to go to your settings then setup wizard and run that it will retest your internet connection ......it detects your new speeds what its doing for me was based off my old speeds lol now that ive done this its getting the new speeds no more half speeds
- Netduma-FraserMar 09, 2019NetDuma PartnerGreat to hear you resolved it! You can also go to QoS > Anti-Bufferbloat > 3 line menu in top left of panel and enter your speeds there
- someguy28Mar 09, 2019Aspirant
oh so i didnt even need to do what i did i could have just put the speeds in that way?
- Netduma-FraserMar 09, 2019NetDuma PartnerYes exactly but your way is correct as well just takes a little longer!
