someguy28
Mar 09, 2019Aspirant
xr700 slow internet speeds wired
i just got my router and my internet speeds are cut more then half download is ussually 400 plus but it only reaches 110 i have disabled qos and its fine but if its enabled thats when it happens im n...
Netduma-Fraser
Mar 09, 2019NetDuma Partner
Great to hear you resolved it! You can also go to QoS > Anti-Bufferbloat > 3 line menu in top left of panel and enter your speeds there
someguy28
oh so i didnt even need to do what i did i could have just put the speeds in that way?
- Netduma-FraserMar 09, 2019NetDuma PartnerYes exactly but your way is correct as well just takes a little longer!
