cloidhamer
Jul 25, 2019Aspirant
XR700 spamming all network ports
I have an issue where all the ports on my network show traffic and the router and any device on my network is unreachable. A reset of the router fixes the issue. When this happened I unplugged each d...
Netduma_Alex
Jul 25, 2019NetDuma Partner
What hardware do you have upstream from the router? If you've got an ISP router you might need to change some settings there to get the XR700 working properly. For example, changing the XR700's IP from 192.168.1.1 to 192.168.x.1 where x is any number you like
- cloidhamerJul 25, 2019Aspirant
I use my own cable modem, so there are no ip issues. It happens randomly and since I have to reset the router there is no way to check the logs.
