cloidhamer
Jul 25, 2019Aspirant
XR700 spamming all network ports
I have an issue where all the ports on my network show traffic and the router and any device on my network is unreachable. A reset of the router fixes the issue. When this happened I unplugged each d...
Jul 25, 2019Guru - Experienced User
What devices and or switches do you have connected?
Do you have any static IP address asigned devices?
I didn't experience this with mine. I have many LAN devices connected along with LAN switches.
What FW version are you on?
Try setting the DHCP IP address pool size to 192.168.1.100 to .200.
cloidhamer wrote:I have an issue where all the ports on my network show traffic and the router and any device on my network is unreachable. A reset of the router fixes the issue. When this happened I unplugged each device to see if it was something on the network. It was not, and since power cycling my router fixed the issue it must be a problem with the XR700. Also I haven;t changed anything on my network since installing the XR700 and have never seen this issue before. Any help would be appreciated.
BTW NetDUMA blows. I was excited for some really cool features, but it has way under delivered and is slow and laggy.
- cloidhamerJul 25, 2019Aspirant
LIke I said this network has been operating flawlessly for 5 years until I added the XR700. I will try a wireshark next time it happens, which should be within the week or sooner, to see if I can gain any data to post here.
It's unfortunate that I paid this much for a router and OS that is clearly not worth it.
- Netduma-FraserJul 25, 2019NetDuma PartnerI have asked Christian_R to add you to the beta group for XR700 firmware. There are a few firmware versions there that are not publicly available, they may help to resolve the issue you're having.
- cloidhamerJul 26, 2019Aspirant
Netduma-Fraser I haven't hear anything from @Christian_R. How do I get the beta firmware. Thanks.
- FURRYe38Jul 25, 2019Guru - Experienced User
Try the beta, There in a UI improvement there...
Also try changing the IP address pool size as well...
What was the prior router you had before the XR?
What all devices do you have connected?
cloidhamer wrote:LIke I said this network has been operating flawlessly for 5 years until I added the XR700. I will try a wireshark next time it happens, which should be within the week or sooner, to see if I can gain any data to post here.
