CSPHX101
Oct 14, 2019Aspirant
XR700 Speedtest between Lan and Wan ports
Hi, Has anyone done some speedtest between Lan and Wan? I've been testing the speed between lan ports and wan ports and the most I get is 537 Mbits/sec. I was expecting atleast 900 Mbits/sec betwe...
Netduma-Fraser
Oct 15, 2019NetDuma Partner
How have you been running the tests exactly?
CSPHX101
Oct 15, 2019Aspirant
Using a gigabit switch,2 wired pcs, XR700 and IPERF3.
That said that are many otherways to test speed between router and switch ports.
How are you testing it?
THX
- Netduma-FraserOct 15, 2019NetDuma PartnerWe actually primarily use iPerf 2 as have found issues using iPerf 3. If you test using iPerf 2 do you get the same results as 3? Are you using multiple streams to test?
- CSPHX101Oct 15, 2019Aspirant
using IPERF3 running multiple threads I do get 998 Mbps.
> iperf3 -c [host] -P 2
Thank you
- Netduma-FraserOct 15, 2019NetDuma PartnerGlad to hear it, just a case of settings then!
