CSPHX101
Oct 14, 2019Aspirant
XR700 Speedtest between Lan and Wan ports
Hi, Has anyone done some speedtest between Lan and Wan? I've been testing the speed between lan ports and wan ports and the most I get is 537 Mbits/sec. I was expecting atleast 900 Mbits/sec betwe...
Netduma-Fraser
Oct 15, 2019NetDuma Partner
How have you been running the tests exactly?
CSPHX101
Oct 15, 2019Aspirant
See attached image.. did same test on other brand similar gigabit routers and they are over 900 Mbps.
I tried the test with all different settings in Netduma turning features off or on with no luck. What should the throughput speed be and how do you test it?
Let me know.
THX
