Scepter2020
Jul 03, 2020Aspirant
XR700 "This device is blocked by Access Control in the router" for one iPhone out of over 60 devices
My DHCP basically just blew up and on one thread, someone from support said to upgrade to the hotfix to XR700 V1.0.1.24 That seemed to fix everything. However, now out of over 60 devices from vario...
- Aug 12, 2020
I stumbled across the "solve" on a stroke of luck. There's some coding fixes that needs done for sure. It's some bizarre problem with the Nighthawk iPhone app.
On both the web interface and the app the devices show online. Disabling, deleting, etc, doesn't do anything to remediate. Here's what works:
Open the iPhone Nighthawk app, disable the device in the iphone app with the toggle, wait a minute, then re-enable the device in the iphone app. It appears to me there must be some messed up backend code where the disable in the iphone app does stop internet access, but it doesn't disable in the router device manager. So there must be some hidden attributes that are set via the iphone app that you can't access via the router web interface.
Netduma-Fraser
Aug 12, 2020NetDuma Partner
I see you've posted on our forum so lets continue there: https://forum.netduma.com/topic/32082-help-please-xr700-this-device-is-blocked-by-access-control-in-the-router/
Scepter2020
Aug 12, 2020Aspirant
- Netduma-FraserAug 12, 2020NetDuma PartnerThanks for letting us know, we'll pass that on to Netgear
