dahliamo
Aug 07, 2020Aspirant
XR700 VPN not working
I have The XR700, when i run My Ethernet cable “ hard wired “ from my XR700 to my Xbox one x it does NOT mask my IP address. VPN works Wirelessly but not hardwired. I’ve tried everything and nothing w...
Netduma-Fraser
Aug 07, 2020NetDuma Partner
Check the Device Manager as it may be that your wired PS4 is appearing as a separate device to the wireless PS4 and so you'll need to add that instead of the wireless version.
dahliamo
I did That awhile back and it gave me double NAT. So that doesn’t work.
- Netduma-FraserAug 08, 2020NetDuma PartnerNot sure I follow with that, are you saying doing that you did actually get a connection through the VPN but you had a double NAT?
- dahliamoAug 08, 2020AspirantYes double NAT when i did It. But i can’t use my Xbox when on double NAT because my ping is over 200 and my speeds are below 3. I shouldn't Have double NAT and i do Not want a wireless connection because my ping is ridiculously high and speeds are low
- Netduma-FraserAug 08, 2020NetDuma PartnerInteresting, for the wired/wireless version of the console give them a reserved IP in LAN Settings. In WAN Settings switch NAT to open, does that resolve it? Do you get an open NAT when using VPN through WiFi?
