thatmyles
Oct 26, 2018Tutor
XR700 VPN Tunnelback issue on Mac
Same problem here on a XR700. Setting the VPN config in the router to forward all traffice doesn't work on Tunnelblick on MacOS. Yes, I updated my config. Selecting "Auto" and using that config works...
mingle123
Oct 29, 2018Tutor
Hi, do youm means, mac connect to XR700 as an vpn client, and want to search the internet? you you select auto, maybe the country you live will affect this feature. You'd better to choose internet and home. Do you set IPv6 wan in XR700 or not?
- Netduma-FraserOct 30, 2018NetDuma PartnerHi mingle, are you having an issue or advising thatmyles on what to do?
