thatmyles
Oct 26, 2018Tutor
XR700 VPN Tunnelback issue on Mac
Same problem here on a XR700. Setting the VPN config in the router to forward all traffice doesn't work on Tunnelblick on MacOS. Yes, I updated my config. Selecting "Auto" and using that config works...
Altsai
Oct 31, 2018NETGEAR Expert
You're using openVPN server. while android openVPN client works but your macbook, might need to check whether config file IOT issue for your macOS (what's OS version?).
you may provide all related info to NTGR support team to fix your issue.
