thatmyles
Oct 26, 2018Tutor
XR700 VPN Tunnelback issue on Mac
Same problem here on a XR700. Setting the VPN config in the router to forward all traffice doesn't work on Tunnelblick on MacOS. Yes, I updated my config. Selecting "Auto" and using that config works...
ErnestTheGreat
Nov 14, 2018NETGEAR Employee Retired
thatmyles What type of setup are you running? Who is you ISP and what modem do you have connected to XR700? Also for the OpenVPN setup on Mac what error messages are you seeing on Tunnelblick logs? What is the MAC OS Version and Tunnelblick version you are running?
