thatmyles
Oct 26, 2018Tutor
XR700 VPN Tunnelback issue on Mac
Same problem here on a XR700. Setting the VPN config in the router to forward all traffice doesn't work on Tunnelblick on MacOS. Yes, I updated my config. Selecting "Auto" and using that config works...
pakman79
Feb 06, 2019Aspirant
I was experiencing the same issues, and I finally got it working.
First, I followed the instructions laid out here by user KevinSharku to change the parameters in the client.conf file:
And then copied the contents of the downloaded files from the router (including the edited client.conf file) to a new folder and changed the extension to a .tblk as instructed here:
https://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer
- Netduma_JackFeb 06, 2019NetDuma PartnerGood job. Thanks for sharing your steps.
