mxa's avatar
mxa
Tutor
May 10, 2019
xr700 wifi disconnecting
I made another post but I dont see it in the main forum so trying again here. I am continuously getting wifi dropouts for certain devices. If i reboot the router or disconnect the device from the w...
  • FURRYe38's avatar
    Did you factory reset and setup from scratch after applying v20? I would try this if you didn't reset.
