mxa
May 10, 2019Tutor
xr700 wifi disconnecting
I made another post but I dont see it in the main forum so trying again here.
I am continuously getting wifi dropouts for certain devices. If i reboot the router or disconnect the device from the w...
- May 10, 2019
Did you factory reset and setup from scratch after applying v20? I would try this if you didn't reset.
mxa
May 10, 2019Tutor
I have tried .8 and that did not help, I also tried 0.20 and that caused more issues (DNS stopped working).
May 10, 2019Guru - Experienced User
- mxaMay 10, 2019Tutor
Yes unfortunately I tried this as well holding the reset in the back and configuring it from scratch. Im going to give it another go because I am broken at this point anyway
- Netduma-FraserMay 10, 2019NetDuma PartnerLet us know how you get on, hopefully it'll be good news.
- FURRYe38May 10, 2019Guru - Experienced User
Try 5Ghz lower channels 36-48.
