mxa
May 08, 2019Tutor
XR700 Wifi disconnects
Hi all,
I am continuously getting wifi dropouts for certain devices. If i reboot the router or disconnect the device from the wifi it may connect again or may not ...only to disconnect a few m...
- May 13, 2019
Any Wifi Neighbors near by? If so, how many?Might try downgrading to v20...
logan_001
May 13, 2019Aspirant
I have the exact same issues...
