mxa's avatar
mxa
Tutor
May 08, 2019
XR700 Wifi disconnects
Hi all,    I am continuously getting wifi dropouts for certain devices. If i reboot the router or disconnect the device from the wifi it may connect again or may not ...only to disconnect a few m...
  • FURRYe38's avatar
    May 13, 2019
    Might try downgrading to v20...
