mxa
May 08, 2019Tutor
XR700 Wifi disconnects
Hi all,
I am continuously getting wifi dropouts for certain devices. If i reboot the router or disconnect the device from the wifi it may connect again or may not ...only to disconnect a few m...
- May 13, 2019
Any Wifi Neighbors near by? If so, how many?Might try downgrading to v20...
mxa
May 13, 2019Tutor
Yes downgrading to 0.20 and hardresetting a couple of times was my solution, I posted this in another thread since this post didnt get visibility until now.
May 13, 2019Guru - Experienced User
Good. Thanks for letting us know. :smileywink:
- logan_001May 13, 2019AspirantMine didnt get better with the downgrade. I have a SB8200 modem. The problem got worse when I change from having two ip addresses down to one with faster service(gigabit). I can no longer get two IP's where I live. I'll try different channels and see where that gets me.
- FURRYe38May 13, 2019Guru - Experienced User
What are your wired speeds?
Changing ISP services will not effect this...
logan_001 wrote:
Mine didnt get better with the downgrade. I have a SB8200 modem. The problem got worse when I change from having two ip addresses down to one with faster service(gigabit). I can no longer get two IP's where I live. I'll try different channels and see where that gets me.- logan_001May 14, 2019AspirantMy wired speeds directly from the modem average about 945, out of the router I cant get above 400mbs. Wireless are a steady 300mbs.
