kratch
Dec 11, 2018Aspirant
XR700 wired connections failed
I have been using a R7000 router for several years and just upgraded to a XR700 2 days ago.
Setup was easy, dumaOS is awesome, and I got open NAT on 4 XBOX one consoles!
Well, today all wired por...
Netduma_Jack
Dec 12, 2018NetDuma Partner
Ah, sorry to hear this. It's worth trying thisL
- A reboot (you've probably already done this I realise)
- If that doesn't fix it, try a factory reset https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
Then if that doesn't fix it, you'll need to seek a replacement I'm sorry to say. NETGEAR are good at getting replacements out very quickly: https://www.netgear.com/support/contact.aspx
