kratch
Dec 11, 2018Aspirant
XR700 wired connections failed
I have been using a R7000 router for several years and just upgraded to a XR700 2 days ago.
Setup was easy, dumaOS is awesome, and I got open NAT on 4 XBOX one consoles!
Well, today all wired por...
Altsai
Dec 13, 2018NETGEAR Expert
I don't see the issue at my side. Maybe you can submit a ticket to NTGR support team for further remote debugging. (by the way, which FW version did you use now? v1.0.1.2 or v1.0.0.20?)
dmiller68
Dec 21, 2018Aspirant
I have the same problem it appears to be DHCP issue. Every few days none of my wired devices can get addresses. Seems like a bug in there code somewhere. I was coming on here to see if there was a work around other then rebooting it which is what I do right now. I have 15-20 devices hardwired and another 20+ on wireless. I wonder if they are not doing large volume testing.
- Netduma-FraserDec 21, 2018NetDuma PartnerIf it's DHCP, set static IP addresses for your wired devices, does that then resolve the issue?
- dmiller68Dec 23, 2018Aspirant
Sure that would be an option. Perfer them to fix it.
- kratchDec 27, 2018Aspirant
Customer support said that this had happened 'several' times and asked if I would try some beta firmware. I told them I didn't pay $500 to beta test an unfinished product. They said they would replace it, but wanted my credit card info to send a replacement. I said forget it and returned it to amazon. What happened to netgear? They used to be good.
