phil_wo
Dec 02, 2018Tutor
XR700: Wireless isolation doesn't work on guest network
When I enable guest network, any user on the guest network is put on the same subnet as the main. I have "Allow guests to see each other and access my local network" unchecked. Guest users are able t...
Netduma_Jack
Dec 03, 2018NetDuma Partner
Hi - if that is not working then something is definitely not correct. I recommend you contact NETGEAR's official support so they can escalate this issue: https://www.netgear.com/support/contact.aspx
