phil_wo
Dec 02, 2018Tutor
XR700: Wireless isolation doesn't work on guest network
When I enable guest network, any user on the guest network is put on the same subnet as the main. I have "Allow guests to see each other and access my local network" unchecked. Guest users are able t...
Altsai
Dec 03, 2018NETGEAR Expert
Yes, even connection via guest wifi, you will be still in the same subnet which is correct.
for the isolation matter, I did not see it before. It's worth to dobule check.
- phil_woDec 03, 2018Tutor
I don't see how that qualifies as a guest network if devices share the same subnet
- Netduma-FraserDec 04, 2018NetDuma PartnerIt's a guest network as:
You don't have to share your private WiFi password
Guests can't access shared LAN devices
