phil_wo
Dec 02, 2018Tutor
XR700: Wireless isolation doesn't work on guest network
When I enable guest network, any user on the guest network is put on the same subnet as the main. I have "Allow guests to see each other and access my local network" unchecked. Guest users are able t...
phil_wo
Dec 03, 2018Tutor
Altsai wrote:
Yes, even connection via guest wifi, you will be still in the same subnet which is correct.
for the isolation matter, I did not see it before. It's worth to dobule check.
I don't see how that qualifies as a guest network if devices share the same subnet
Netduma-Fraser
Dec 04, 2018NetDuma Partner
It's a guest network as:
You don't have to share your private WiFi password
Guests can't access shared LAN devices
