jerkychew899
Apr 27, 2019Follower
XR700 wireless suddenly disabled
The Wifi on my Nighthawk stopped working suddenly last night. When I look in system information it shows all my network configurations intact, but it says they are all disabled. I can't find a place ...
schumaku
Apr 27, 2019Guru - Experienced User
Try the physical WiFi button (the second from the right)! Is the LED under the button on or off?
Netduma_Jack
Apr 29, 2019NetDuma Partner
Best check the LED as schumaku suggested - something we accidentally once did and took us 15 mintues to figure out lol 🤦‍♂️
- schumakuApr 29, 2019Guru - Experienced User
Beware - no cat access allowed to the (cozy warm) wireless routers! And not the first and not the last human who would have disabled it on dust removal.
- Netduma_JackApr 29, 2019NetDuma Partner
Absolutely. Because we're always messing with the routers we assumed someone had broken something via software. Took us far longer than it should to solve it.
