DarienAL
Mar 24, 2020Tutor
XRM570 - separate SSID = separate networks?
If I utilize the ability of the XRM570 to have separate SSID's for my 2.4 and 5ghz bands are those actually isolated networks? Can devices/resources on one network see those on the other and can devi...
Netduma-Fraser
Mar 24, 2020NetDuma Partner
They're not isolated because it is all apart of your local network and they will all be on the same subnet 192.168.1.x for example.
- DarienALMar 24, 2020TutorThanks
